preparatory kanna
- crannygoat
Re: preparatory kanna
So Yamashita from Japan-Tools, showed a disposable blade kanna being used as a scrub plane. Japan woodworker sells a 55mm version. Here is a link to a 65mm version on Rakten. You can often find that same plane being sold on eBay by a seller in Japan. I've often thought that a Tsunesaburo high speed steel blade kanna may also be a good choice, but they can be a little pricey.
I use an old stanley jack plane with a highly cambered blade for rough scrubbing. Something I do very little of these days. I suppose a highly cambered 60mm kanna would be a good choice.
Linguistically, a scrub plane would be called an ara-shiko-ganna 荒仕工鉋, ara-kanna/ara-ganna, 荒鉋, for short.
- crannygoat
- Evans
Isn't surface preparation the kind of thing a yari-ganna "spear plane" would be used for?
Or am I underestimating the capabilities of a yari-ganna?
Chōna can be used for roughing and finishing. Like the planes, a more curved blade can be used to hog off more material, and finish dressing the surface is effected with a nearly flat blade.
These days the chōna and yari-ganna are used mostly to leave a decorative tooled surface behind on the wood.
The yari-ganna stems from an era before Chinese-style planes were introduced to Japan. At that time, an abundance of choice straight-grained timber allowed a fair amount of timber to be cleanly riven, which left a fairly flat and clean surface which could cleaned up afterward with the yari-ganna. A piece of timber with less cooperative grain would be hewn to shape with a chōna, and it can leave a pretty good surface if wielded with skill. Often a Chōna does/did leave the final surface.Evans wrote:Isn't surface preparation the kind of thing a yari-ganna "spear plane" would be used for?
Users browsing this forum: No registered users and 43 guests
