The stone is dark and smooth. Here it is all cleaned up for its closeup...
I had a Kunikei blue steel chisel that I needed to sharpen. I took it from 500#, 800#, 1000#, to the aoto. Normally, I would go from 800# to 2000#, but I had the sigma handy. On the aoto, I raised a slurry with a 400# atoma. After a couple of minutes on the aoto, here are the results...
This chisel could cut through a sheet of paper by pushing straight on the edge. It was a more than acceptable edge to work with. I would describe the finish as a cloudy mirror finish.
I next worked the chisel on my shiro suita. You can see the mirror finish is still cloudy, but a bit clearer.
I'll have to jig up a consistent way of photographing the edges of blades for better comparisons.
