I recently took a chance on a house-brand diamond plate from Chef Knives to Go, which is nominally 400
grit on one side and 1000 on the other. If the one I got is representative, then I'm impressed. It's quite
flat and cuts well, though it's *not* a coarse material-hogger. It does have a grid pattern to help with the
sticking issue too, but it's so shallow that I'm not sure it helps. For $35 it seems like a bargain though, especially if they're all this flat. I have no financial interest in CKTG, et c.
One caveat: the plate is listed as being 8" by 2.75", but the one I received is 7.8" by 2.5".
-CW
A pretty good Diamond flattening plate
- Gadge
Re: A pretty good Diamond flattening plate
I bought half a dozen from China. Pretty sure it is the same as you describe.
Flat and cut well. Steel plate so quite heavy. 31 Australian dollars (about USD20). Free shipping. Bargain!
- Carey
My first thoughts were: "heavy- that's good, but probably not flat". Then "hmm.. flat too?
Probably won't cut". But it does, better than others I've used, in fact I mainly use the 1000
grit side and it's lasting well so far.
-CW
You got them for around 20 USD? Now that's a serious bargain! Yeah, they are stout, too.Gadge wrote:I bought half a dozen from China. Pretty sure it is the same as you describe.
-CW
Users browsing this forum: No registered users and 38 guests
