No I don't. Or, to be more accurate, I haven't had a need to attempt that. If a blade were trashed though, with a big chip out of it, I would consider using the belt on the main bevel, but only for rough material removal. It would be back to the coarse stones after that.Yxoc wrote:Ah, I see. Do you grind the main bevel with it, is it flat enough?
That said, I'm sure there are better made and more accurate vertical belt sanding machines that would do a decent job for rough grinding.
