Debating chisels...
Re: Debating chisels...
I have a 7.5mm Zenshō-saku, and 15mm Ōuchi-saku mortise chisels. Their use has been limited to practise in douglas fir and live oak. The Zenshō is blue steel. I am not sure about the type of steel for the Ōuchi. The Zenshō came with a 35° bevel from the factory. The Ōuchi had a 30° bevel, and was crumbling quite badly, so I partially increased the bevel to 35°. I did not want to waste too much steel, so I only changed the bevel enough to allow me to find the bevel when sharpening.
My recent Ouchi gouges are white steel #2, is that a recent Ouchi or vintage? I believe the older ones are often white steel #1.
Thanks for supplying info on the cutting edges. I think 35 is fine, so hopefully the yamahiros can support that sort of cutting angle or even more shallow if I can get a little greedy.
Hehehe, figure you guys might get a kick out of this;
The Ouchi is vintage. I was lucky enough to pickup additionally a 12mm and 18mm at the same time. I don't know about white steel #1. My first bench chisels were Ouchi's from Japan Woodworker in the '80's. Pretty sure they are WS #2. Shortly after that purchase, I took a 25 year hiatus from woodworking. No connection to the quality of the chisels...
Are those chisels your Koyamaichi's with ebony handles?
Oh ok, they must have been using both steels all the way through.
These are Kikuhiromaru's, vintage from the late 80's with rosewood handles. White steel #1, been putting them to use lately, they're very nice to use. The edge holds up nicely. Getting them prepped has been quite a chore however.
Brian,
Can I ask what bevel angle you have your Kikuhiromaru chisels set? I only have a couple of white steel #1 chisels - "sword steel" from Imai. They are second hand, and came with near 20 degree bevel angles. I have raised them to 25, and may raise them to 30. They do not like chopping late wood in Douglas fir.
