Gallery of Finished Work
Post pictures of your completed tool box build here!
charlie
Re: Input please
Wed Apr 11, 2012 11:35 pm
Here's my walnut toolbox:
I eliminated the interior partitions to allow room for long saws I want to put in the bottom. (Yes, the top of the sides are slightly curving inward already.)
For fear of wedges I glued the through tenons to the sides.
For fear of hell tenons I glued 8/10ths of the cherry keys on the bottom, but wedged the tops. I did do the two center tenons in the hellacious manner, and it worked well. I signified these by using ebony wedges, instead of walnut, which I used on the others.
I put an application of walnut oil on it and probably will leave it at that.
I didn't have stock wide enough to do the handle the way you did it, so I laminated some thinner pieces.
Here's a sketch:
And here are the parts:
A little bit of carving on the top:
I screwed rails to the side and dropped the ends of the tray 1/4" below it's sides to hold it in place and used what I have been told is a katagi sakuri kanna for the sliding dovetail:
After initial planing to rough thickness, no machines were used in the making of this toolbox.
With apologies for the photo quality.
Re: Input please
Thu Apr 12, 2012 4:26 am
That's a nice looking toolbox. Congratulations!
Re: Input please
Thu Apr 12, 2012 8:00 am
Charlie - outstanding work!! I was really pleased to see your finished piece and think it came out really well. Clean execution and I'm sure your work will inspire other members here.
At some point i would like to post pictures on the Carpentry Way blog of study group members with their finished pieces, so if you would consider having a friend or family member snap a pic of you with your toolbox, I would appreciate it. And if you would prefer to remain anonymous, that's fine - if there is a picture of the toolbox you would be okay with me using, please let me know.
Thu Apr 12, 2012 8:02 am
Here's the place to post up pics of your completed toolbox.
Dan McC
Re: Gallery of Finished Work
Sun Nov 11, 2012 6:24 pm
OK, here is my finally completed toolbox. The body is catalpa, the bottom is Monterey cypress, and the lid is elm. The outside has a couple coats of Tried and True on it, the inside is shellac. The pins that hold the battens to the lid are ebony. I have not done any trays, I will leave that to 'the future'.
Some of you may recall that during the build I had an oops on one bottom corner. I patched it up, and with the passing of a bit of time to darken the patch and the oil finish, it is not bad.
I learned a tremendous amount from the project, thank you Chris!! Looking forward to the next one!
Dan
Sun Nov 11, 2012 6:41 pm
Dan,
excellent work - really turned out well!! I'm glad you're getting a lot out of this and can't wait to see what comes next!
Mon Jan 07, 2013 4:51 pm
On the 1 year anniversary month of my joining the study group, I am finally prodded to posting some photos of my toolbox. I do not consider the toolbox finished, as it is still missing tool trays, final surface preparation (lots of tear out), and an oil finish on the walnut.
My toolbox measures 28" x 14-1/2" x 10". The body is douglas fir and the top and handles are claro walnut. The toolbox turned out so much better than I could have hoped in the beginning. After being in its current state for the past 6 months, I am happy to report that everything is still straight, true, and tight. The top attaches securely with any binding.
Mon Jan 07, 2013 6:46 pm
That's beautiful! Very nice work David.
Return to “Gallery”
