I finally got myself a set of nomi and I need to go about getting them set up to go.
Is it necessary to use a kanaban to flatten the back or can I use a water stone? I don't have a kanaban so I'll have to buy one if needed.
preparing nomi
Re: preparing nomi
Thanks for initiating a topic of discussion!
You can use a variety of media to flatten the back of a chisel. A kanaban works fine, but I find the grinding powders are kinda messy. I used to have one but I got rid of it.
A diamond plate works, but you don't want something too coarse. Sandpaper on granite or glass plate works, and waterstones work. The key point in preparing the back of a chisel is that whatever you use to do the flattening should be dead flat. So, if using waterstones, especially the coarser ones, re-flatten the stones FREQUENTLY and don't use much pressure when stroking the chisel on the stone. It's okay to work the full surface of the ura, but concentrate most of your strokes over the last 1/4 of the blade. Try to keep the 'legs' on the side of the ura fairly thin, maxing out the life of the hagane.
kakashika
Re: preparing nomi
Just trying to generate some movement here mate.
I'll skip the kanaban and try either water stones or sandpaper. I have some of the 3m diamond film from LV, do you think that would work?
Re: preparing nomi
I have some of that microfinishing paper, but haven't actually tried it yet, so i can't say. The sheets are a bit on the small side tho...
kakashika
Re: preparing nomi
I decided that I wasn't happy with the set of nomi I had so I sold them on ebay at a slight loss and got a set by Kunitoshi. I was reading your blog posts about the Yamahiro and Kunitoshi but it appears that the tests weren't finished? What are your thoughts on the Kunitoshi?
kakashika
Re: preparing nomi
I'm happy with them so far but the proof will be once they're set up and hit with a genno
Re: preparing nomi
They're certainly reasonably priced, and are available without much of a wait. If you don't have one, those hoop setting tools are very much worth getting.
kakashika
Users browsing this forum: No registered users and 35 guests
