I don't agree with his conclusions. It's empirically obvious that natural stones, finishers at least, finish finer than they start. I haven't, however, heard a good explanation of the mechanism by which that happens, so it's interesting to see some imagery of the process. Of course, that could be because there are no English translations of Japanese research, which I would love to see. I think he discounts the contributions that the broken-down clay binder makes to the sharpening process, which I suspect plays a large role in cushioning the steel from coarser particles, and is perhaps capable of at least abrading soft iron. The fact that he uses a razor, with a small surface area in contact with the stone, may also contribute to his conclusions. I think it's possible that a wide beveled tool would work the slurry more, further breaking it down.
As far as surfacing stones, I flatten and round corners with diamond plates, and then use nagura and tomo nagura to smooth the stone face. After surfacing, the stone is reflective when viewed at an angle. I find that a properly conditioned stone feels more engaged with the blade, cuts faster, and yields slurry faster.
Hand techniques
Here's a razor guy who uses a natural stone for a long time, working the slurry, and the finish he gets on the blade is intriguing:
https://www.youtube.com/watch?v=AJqy49-yHXw
Re: Hand techniques
I wondered the same thing too.The fact that he uses a razor, with a small surface area in contact with the stone, may also contribute to his conclusions. I think it's possible that a wide beveled tool would work the slurry more, further breaking it down.
- dmccurtis
Re: Hand techniques
I've watched that video, and Dr. Matt's others. It's intriguing, but I find it hard to draw conclusions from. HIs postulation that adding CBN to the stone catalyzes slurry break-down, and that may be, but it seems to be a solution in need of a problem. The image he shows of the non-'supercharged' Nakayama edge looks surprisingly poor, and I don't think indicative of a normal result. It's hard to tell from small pictures, but to me, it looks like the results from a stone either too hard for normal use, or too hard for its user.
Not to make things too personal, but I tend to take sharpening advice from razor sharpeners with a grain of salt. The razor community has lots of flavour of the month products and wonder-techniques, and lots of contradictory ideas about what works and why. It's even worse when Japanese naturals are added to the mix, with so little good information about them readily available.
Re: Hand techniques
I thought the CBN on Nakayama was interesting as well, just didn't know if it would have any relevance in woodworking. I have a jewelers loupe in my house....and have contemplated inspecting my edges with it. I forget if it was this forum, but I think a few of you guys do this as well?
- Gadge
Re: Hand techniques
I've used a loupe for years and wouldn't be without one when experimenting. It can be a shock to see your prized finish up close.
- dmccurtis
Users browsing this forum: No registered users and 47 guests
