Medicine Cabinets - Build thread
Fri Jan 22, 2016 6:32 pm
Evening!
Building a pair of medicine cabinets for my house to replace some real junkers installed by the original builder. These will set into the wall and reveal about 2" of the cabinet.
This first cabinet is the prototype, so there will be limited photos of the process, but the second one I will detail the joinery and build as I progress through it.
Because this is in a high moisture environment I've decided to use cypress, leaning toward quarter sawn material. I bought 4/4 material with designs on ripping it down to the required thickness by hand.
Some of the pieces did not call for resawing and so I used David's jack plane to remove the majority of the material. This removed material in a hurry....I took swipes where easily 1/16" of material was removed.
Followed up with the try plane
Each board was then fine tuned with the #4 plane and then a finish pass was done with the Kanna leaving a super bright surface. The #4 left a surprisingly bright surface on this material but was ever so slightly out done by the Kanna with it's low angle bedding.
Ripping some material for shelving;
Sticking with thin material on this project and joinery which relies minimally upon glue.Image
If you look closely you may notice that those are mitered edge dovetails, both front and back. I wanted to hide the grooves that will ultimately capture the back panel and also show a miter on the inside of the cabinet.
The outside 1.5" will be wrapped in a surround (door frame), but when the door is opened the leading edges of those miters will be revealed.
The shelves are housed through tenons.
Hope you guys enjoy!
Re: Medicine Cabinets - Build thread
Mon Jan 25, 2016 8:19 am
Building the framed surround. Since this cabinet is going to be set into a wall, the only visible part will be the surround.
Next will be the back panel and the door.
Wed Jan 27, 2016 8:25 pm
As always, I love watching your process!! Very crisp.
Fri Jan 29, 2016 1:07 am
Thanks Paul!
I'll follow up with another update soon.
Ken
Fri Jan 29, 2016 2:17 am
Beautiful work!
If someday I can get half of your quality, I'd be very happy.
I'm looking forward to seeing this come together.
Tue Feb 02, 2016 7:50 pm
Thanks Ken! I have a large-ish update for this as I continue along with the second case.
Wed Feb 03, 2016 11:54 am
I'm continuing this build on my blog, in order to simplify multiple postings
https://brianholcombewoodworkerblog.wor ... -casework/
In this post I'm doing the layout and detail work of the inner case and begin dovetailing the outer case.
Check it out and give me feedback, if you guys don't mind the extra click it saves some work on my end, but I appreciate any feedback.
Thu Feb 04, 2016 1:06 am
Evening gents;
Continuing my medicine cabinet build, I have a detailed version on my new blog.
https://brianholcombewoodworkerblog.wor ... k-part-ii/
Thu Feb 04, 2016 7:25 pm
Thu Feb 04, 2016 7:59 pm
Good work Brian.
Users browsing this forum: No registered users and 11 guests
